Salta al contenuto principale
HP Pavilion 13-s128nr Back Panel Replacement
Cosa ti serve
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: passo 2, immagine 1 di 1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: passo 3, immagine 1 di 2 HP Pavilion 13-s128nr Back Panel Replacement: passo 3, immagine 2 di 2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 782
