Salta al contenuto principale
HP Pavilion 11-n010dx Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 11-n010dx Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 11-n010dx Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion 11-n010dx Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion 11-n010dx Hard Drive Replacement: passo 2, immagine 3 di 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion 11-n010dx Hard Drive Replacement: passo 3, immagine 2 di 2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion 11-n010dx Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Hard Drive Replacement: passo 6, immagine 1 di 2 HP Pavilion 11-n010dx Hard Drive Replacement: passo 6, immagine 2 di 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Hard Drive Replacement: passo 7, immagine 1 di 1
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Hard Drive Replacement, Hard Drive: passo 8, immagine 1 di 1
    • Use the Phillips #0 to remove the three 3mm screws holding the hard drive in place.
  9. HP Pavilion 11-n010dx Hard Drive Replacement: passo 9, immagine 1 di 2 HP Pavilion 11-n010dx Hard Drive Replacement: passo 9, immagine 2 di 2
    • Carefully lift the hard drive out of place using the tag.
  10. HP Pavilion 11-n010dx Hard Drive Replacement: passo 10, immagine 1 di 3 HP Pavilion 11-n010dx Hard Drive Replacement: passo 10, immagine 2 di 3 HP Pavilion 11-n010dx Hard Drive Replacement: passo 10, immagine 3 di 3
    • Gently pull on the cable connector to disconnect the hard drive from your device.
Conclusione
Altre 5 persone hanno completato questa guida.
Joseph Lintz
Membro da: 09/15/16
915 Reputazione
5 Guide realizzate
USF Tampa, Team 11-5, Blackwell Fall 2016 Membro di USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Membri
5 Guide realizzate
2 Commenti
Thanks a lot Joseph ! Works well for the model 11-n000nf !
Nicolas - Replica
Thanks Joseph-I was able to get it open, disconnect the battery and ordered a new battery. We’ll see if this corrects the problem. Computer was sleeping for over a year. Thank you for your pictures and easy to follow instructions.
Beverlyn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 5,489
