Salta al contenuto principale
HP Pavilion 11-n010dx Bottom Case Replacement
Cosa ti serve
  1. HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: passo 1, immagine 1 di 2 HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
    • Use Phillips #0 to remove four 9mm screws.
    • Use Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Bottom Case Replacement: passo 2, immagine 1 di 3 HP Pavilion 11-n010dx Bottom Case Replacement: passo 2, immagine 2 di 3 HP Pavilion 11-n010dx Bottom Case Replacement: passo 2, immagine 3 di 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Bottom Case Replacement: passo 3, immagine 1 di 2 HP Pavilion 11-n010dx Bottom Case Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
Conclusione
Joseph Lintz
Membro da: 09/15/16
915 Reputazione
5 Guide realizzate
USF Tampa, Team 11-5, Blackwell Fall 2016 Membro di USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,376
