Salta al contenuto principale
HP Pavilion 11-n010dx Battery Replacement
Cosa ti serve
  1. HP Pavilion 11-n010dx Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 11-n010dx Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Battery Replacement: passo 2, immagine 1 di 3 HP Pavilion 11-n010dx Battery Replacement: passo 2, immagine 2 di 3 HP Pavilion 11-n010dx Battery Replacement: passo 2, immagine 3 di 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion 11-n010dx Battery Replacement: passo 3, immagine 2 di 2
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Battery Replacement: passo 4, immagine 1 di 1
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Battery Replacement: passo 5, immagine 1 di 2 HP Pavilion 11-n010dx Battery Replacement: passo 5, immagine 2 di 2
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Battery Replacement: passo 6, immagine 1 di 2 HP Pavilion 11-n010dx Battery Replacement: passo 6, immagine 2 di 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Battery Replacement: passo 7, immagine 1 di 1
    • Remove the battery from your device.
Conclusione
Altre 3 persone hanno completato questa guida.
Joseph Lintz
Membro da: 09/15/16
915 Reputazione
5 Guide realizzate
USF Tampa, Team 11-5, Blackwell Fall 2016 Membro di USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Membri
5 Guide realizzate
2 Commenti
Only four 6mm screws retaining battery, middle screw secures by passing through back cover. Otherwise very helpful.
norman.huntbach - Replica
i followed every step on this guide and when i was finished my laptop wouldn’t turn on
premium destroyers - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,124
