Salta al contenuto principale
HP Pavilion 11 x360 Motherboard Replacement
Cosa ti serve
  1. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: passo 1, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: passo 1, immagine 2 di 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: passo 2, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: passo 2, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: passo 2, immagine 3 di 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: passo 3, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: passo 3, immagine 2 di 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Motherboard Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Motherboard Replacement: passo 5, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 5, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 5, immagine 3 di 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Motherboard Replacement: passo 6, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Motherboard Replacement: passo 7, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the battery.
  8. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: passo 8, immagine 1 di 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: passo 9, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: passo 9, immagine 2 di 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: passo 10, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: passo 10, immagine 2 di 2
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Motherboard Replacement: passo 12, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 12, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 12, immagine 3 di 3
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Motherboard Replacement: passo 13, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 13, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 13, immagine 3 di 3
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: passo 14, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: passo 14, immagine 2 di 2
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: passo 15, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: passo 15, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: passo 15, immagine 3 di 3
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: passo 16, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: passo 16, immagine 2 di 2
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: passo 17, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: passo 17, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: passo 17, immagine 3 di 3
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: passo 18, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: passo 18, immagine 2 di 2
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: passo 19, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: passo 19, immagine 2 di 2
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: passo 20, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: passo 20, immagine 2 di 2
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: passo 21, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: passo 21, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: passo 21, immagine 3 di 3
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Motherboard Replacement: passo 22, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement: passo 22, immagine 2 di 2
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Motherboard Replacement: passo 23, immagine 1 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 23, immagine 2 di 3 HP Pavilion 11 x360 Motherboard Replacement: passo 23, immagine 3 di 3
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Motherboard Replacement: passo 24, immagine 1 di 1
    • Remove the RAM.
  25. HP Pavilion 11 x360 Motherboard Replacement: passo 25, immagine 1 di 2 HP Pavilion 11 x360 Motherboard Replacement: passo 25, immagine 2 di 2
    • Lift up the heat sink to remove it from the motherboard.
Conclusione
Altre 10 persone hanno completato questa guida.
Emily
Membro da: 01/22/15
487 Reputazione
1 Guida realizzata
Cal Poly, Team 19-9, Maness Winter 2015 Membro di Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Membri
12 Guide realizzate
Un commento
La tarjeta madre soportara un intel core i5?
Rodolfo Giron - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 43
Tutti i Tempi: 10,812
