Salta al contenuto principale
HP Omni 10 Battery Replacement
Cosa ti serve
  1. HP Omni 10 Battery  Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10 Battery  Replacement: passo 2, immagine 1 di 1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10 Battery  Replacement: passo 3, immagine 1 di 1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10 Battery  Replacement: passo 4, immagine 1 di 2 HP Omni 10 Battery  Replacement: passo 4, immagine 2 di 2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10 Battery  Replacement: passo 5, immagine 1 di 2 HP Omni 10 Battery  Replacement: passo 5, immagine 2 di 2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
Conclusione
Altre 3 persone hanno completato questa guida.
Alex Miller
Membro da: 10/11/16
345 Reputazione
5 Guide realizzate
USF Tampa, Team 1-1, Leahy Fall 2016 Membro di USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 4,034
