Salta al contenuto principale
HP Omen 15-ce019dx Battery Replacement
Cosa ti serve
  1. HP Omen 15-ce019dx Battery Replacement, Battery: passo 1, immagine 1 di 3 HP Omen 15-ce019dx Battery Replacement, Battery: passo 1, immagine 2 di 3 HP Omen 15-ce019dx Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Unplug the computer and power it off completely.
  2. HP Omen 15-ce019dx Battery Replacement: passo 2, immagine 1 di 3 HP Omen 15-ce019dx Battery Replacement: passo 2, immagine 2 di 3 HP Omen 15-ce019dx Battery Replacement: passo 2, immagine 3 di 3
    • Turn the laptop over so the bottom is facing up.
    • Remove the eight 1.2 mm screws around the frame using a Phillips #00 screwdriver.
    • Unscrew the two 1.2 mm screws at the top using a Phillips #00 screwdriver. These screws stay in the back of laptop, so when you hear a clicking sound, the screw is removed and you may proceed.
  3. HP Omen 15-ce019dx Battery Replacement: passo 3, immagine 1 di 3 HP Omen 15-ce019dx Battery Replacement: passo 3, immagine 2 di 3 HP Omen 15-ce019dx Battery Replacement: passo 3, immagine 3 di 3
    • At the top of the laptop, there is gap between the back cover and the rest of the laptop.
    • Gently pop the back off by gripping the top edge where the gap is and pulling up. The rest of the frame should pop up as you pull.
    • There should be popping sounds as the frame comes up around all the edges.
    • It will take some force to remove the frame for the first time. Don't be afraid to really pull it up; just be patient and don't rip it up all at once. Each edge should pop up as you pull.
  4. HP Omen 15-ce019dx Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four 1.2 mm screws from the top of the battery using a Phillips #00 screwdriver.
  5. HP Omen 15-ce019dx Battery Replacement: passo 5, immagine 1 di 2 HP Omen 15-ce019dx Battery Replacement: passo 5, immagine 2 di 2
    • Pull up on the battery from the top, and slide it out of place.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 70
Ultimi 30 Giorni: 289
Tutti i Tempi: 6,681
