Salta al contenuto principale
HP Omen 15-ax243dx Ventilation Fans Replacement
Cosa ti serve
  1. HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: passo 1, immagine 1 di 2 HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: passo 1, immagine 2 di 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Ventilation Fans Replacement: passo 2, immagine 1 di 2 HP Omen 15-ax243dx Ventilation Fans Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Ventilation Fans Replacement: passo 3, immagine 1 di 2 HP Omen 15-ax243dx Ventilation Fans Replacement: passo 3, immagine 2 di 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Ventilation Fans Replacement: passo 4, immagine 1 di 2 HP Omen 15-ax243dx Ventilation Fans Replacement: passo 4, immagine 2 di 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Ventilation Fans Replacement, Ventilation Fans: passo 5, immagine 1 di 1
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  6. HP Omen 15-ax243dx Ventilation Fans Replacement: passo 6, immagine 1 di 2 HP Omen 15-ax243dx Ventilation Fans Replacement: passo 6, immagine 2 di 2
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
  7. HP Omen 15-ax243dx Ventilation Fans Replacement: passo 7, immagine 1 di 1
    • The fans can now be removed from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
vangnam
Membro da: 10/19/17
594 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 5,626
