Salta al contenuto principale
HP Omen 15-ax243dx Screen Replacement
Cosa ti serve
  1. HP Omen 15-ax243dx Screen Replacement, Battery: passo 1, immagine 1 di 2 HP Omen 15-ax243dx Screen Replacement, Battery: passo 1, immagine 2 di 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Screen Replacement: passo 2, immagine 1 di 2 HP Omen 15-ax243dx Screen Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Screen Replacement: passo 3, immagine 1 di 2 HP Omen 15-ax243dx Screen Replacement: passo 3, immagine 2 di 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Screen Replacement: passo 4, immagine 1 di 2 HP Omen 15-ax243dx Screen Replacement: passo 4, immagine 2 di 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Screen Replacement, Screen: passo 5, immagine 1 di 2 HP Omen 15-ax243dx Screen Replacement, Screen: passo 5, immagine 2 di 2
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #00 Phillips screwdriver head.
    • Be cautious of where the screws come out from, some will only fit in the same location.
  6. HP Omen 15-ax243dx Screen Replacement: passo 6, immagine 1 di 3 HP Omen 15-ax243dx Screen Replacement: passo 6, immagine 2 di 3 HP Omen 15-ax243dx Screen Replacement: passo 6, immagine 3 di 3
    • Remove the tape holding the wires down
    • Disconnect the wires from the wifi chip
    • When removing the wires from the wifi chip, be careful to not damage the connectors.
  7. HP Omen 15-ax243dx Screen Replacement: passo 7, immagine 1 di 3 HP Omen 15-ax243dx Screen Replacement: passo 7, immagine 2 di 3 HP Omen 15-ax243dx Screen Replacement: passo 7, immagine 3 di 3
    • Flip the switch up that holds the screen cable in place
    • Lift up and pull back the cable from the insert
  8. HP Omen 15-ax243dx Screen Replacement: passo 8, immagine 1 di 2 HP Omen 15-ax243dx Screen Replacement: passo 8, immagine 2 di 2
    • Lift the base of the device up to separate the hinges from the body of the device
  9. HP Omen 15-ax243dx Screen Replacement: passo 9, immagine 1 di 1
    • Slide the base of the device out from under the hinges
    • The screen can now be replaced
Conclusione
vangnam
Membro da: 10/19/17
594 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 51
Tutti i Tempi: 5,259
