Salta al contenuto principale
HP Omen 15-ax243dx Hard-Drive Replacement
Cosa ti serve
  1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Omen 15-ax243dx Hard-Drive Replacement, Battery: passo 1, immagine 2 di 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Hard-Drive Replacement: passo 2, immagine 1 di 2 HP Omen 15-ax243dx Hard-Drive Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Hard-Drive Replacement: passo 3, immagine 1 di 2 HP Omen 15-ax243dx Hard-Drive Replacement: passo 3, immagine 2 di 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Hard-Drive Replacement: passo 4, immagine 1 di 2 HP Omen 15-ax243dx Hard-Drive Replacement: passo 4, immagine 2 di 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Hard-Drive Replacement, Hard-Drive: passo 5, immagine 1 di 1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Hard-Drive Replacement: passo 6, immagine 1 di 3 HP Omen 15-ax243dx Hard-Drive Replacement: passo 6, immagine 2 di 3 HP Omen 15-ax243dx Hard-Drive Replacement: passo 6, immagine 3 di 3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Hard-Drive Replacement: passo 7, immagine 1 di 1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Hard-Drive Replacement: passo 8, immagine 1 di 3 HP Omen 15-ax243dx Hard-Drive Replacement: passo 8, immagine 2 di 3 HP Omen 15-ax243dx Hard-Drive Replacement: passo 8, immagine 3 di 3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
Conclusione
Altre 3 persone hanno completato questa guida.
vangnam
Membro da: 10/19/17
594 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 69
Tutti i Tempi: 8,223
