Salta al contenuto principale
HP Omen 15-5002xx Wi-Fi Card Replacement
Cosa ti serve
  1. HP Omen 15-5002xx Wi-Fi Card Replacement, Back Cover: passo 1, immagine 1 di 2 HP Omen 15-5002xx Wi-Fi Card Replacement, Back Cover: passo 1, immagine 2 di 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Wi-Fi Card Replacement, Wi-Fi Card: passo 2, immagine 1 di 1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  3. HP Omen 15-5002xx Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
Conclusione
Gateway, Team 1-1, Saknee Fall 2021 Membro di Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 464
