Introduzione
Follow this guide to replace the motherboard of your HP Omen 15-5002xx gaming laptop.
Before beginning this repair, be sure to power off your device and unplug it from external power.
Cosa ti serve
Flip the laptop upside down so the backside is facing up.
Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
Unscrew all 14 screw with the J00 JIS Screwdriver.
Open the case slowly from opposite sides of the laptop.
Use the J00 JIS screwdriver to remove eight screws securing the battery.
Remove the twelve big screws with the J00 JIS screwdriver.
Remove all eight small screws with the 1.5 flathead screwdriver.
Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
