Salta al contenuto principale
HP Omen 15-5002xx Keyboard Replacement
Cosa ti serve
  1. HP Omen 15-5002xx Keyboard Replacement, Back Cover: passo 1, immagine 1 di 2 HP Omen 15-5002xx Keyboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Keyboard Replacement, Battery: passo 2, immagine 1 di 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Keyboard Replacement: passo 3, immagine 1 di 2 HP Omen 15-5002xx Keyboard Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Keyboard Replacement, Fan: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Flathead 1.5 mm Screwdriver
    $5.49
    Compra
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Keyboard Replacement: passo 5, immagine 1 di 2 HP Omen 15-5002xx Keyboard Replacement: passo 5, immagine 2 di 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
  6. HP Omen 15-5002xx Keyboard Replacement, Wi-Fi Card: passo 6, immagine 1 di 1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  7. HP Omen 15-5002xx Keyboard Replacement: passo 7, immagine 1 di 1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
  8. HP Omen 15-5002xx Keyboard Replacement, Motherboard: passo 8, immagine 1 di 1
    $5.49
    Compra
    • Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
  9. HP Omen 15-5002xx Keyboard Replacement: passo 9, immagine 1 di 3 HP Omen 15-5002xx Keyboard Replacement: passo 9, immagine 2 di 3 HP Omen 15-5002xx Keyboard Replacement: passo 9, immagine 3 di 3
    • Disconnect the four cables attached to the motherboard.
  10. HP Omen 15-5002xx Keyboard Replacement: passo 10, immagine 1 di 2 HP Omen 15-5002xx Keyboard Replacement: passo 10, immagine 2 di 2
    • Disconnect the remaining four connectors from the motherboard.
    • Remove the motherboard.
  11. HP Omen 15-5002xx Keyboard Replacement, Keyboard: passo 11, immagine 1 di 1
    $5.49
    Compra
    • Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
    • All necessary screws are numbered from 1-51 on the side of each screw hole.
  12. HP Omen 15-5002xx Keyboard Replacement: passo 12, immagine 1 di 2 HP Omen 15-5002xx Keyboard Replacement: passo 12, immagine 2 di 2
    • Slowly pull the electricity tape off of the computer.
    • You are able to replace the electricity tape or keep the tape attached with the wire.
  13. HP Omen 15-5002xx Keyboard Replacement: passo 13, immagine 1 di 2 HP Omen 15-5002xx Keyboard Replacement: passo 13, immagine 2 di 2
    • With two hands, lift the keyboards from the sides.
Conclusione
Hassan Isse
Membro da: 09/01/21
97 Reputazione
1 Guida realizzata
Gateway, Team 1-1, Saknee Fall 2021 Membro di Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,222
