Salta al contenuto principale
HP Omen 15-5002xx Fan Replacement
Cosa ti serve
  1. HP Omen 15-5002xx Fan Replacement, Back Cover: passo 1, immagine 1 di 2 HP Omen 15-5002xx Fan Replacement, Back Cover: passo 1, immagine 2 di 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Fan Replacement, Battery: passo 2, immagine 1 di 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Fan Replacement: passo 3, immagine 1 di 2 HP Omen 15-5002xx Fan Replacement: passo 3, immagine 2 di 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Fan Replacement, Fan: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Flathead 1.5 mm Screwdriver
    $5.49
    Compra
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Fan Replacement: passo 5, immagine 1 di 2 HP Omen 15-5002xx Fan Replacement: passo 5, immagine 2 di 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
Conclusione
Gateway, Team 1-1, Saknee Fall 2021 Membro di Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,665
