Salta al contenuto principale
HP Officejet Pro 8625 Motherboard Replacement
Cosa ti serve
  1. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: passo 1, immagine 1 di 3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: passo 1, immagine 2 di 3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: passo 1, immagine 3 di 3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Motherboard Replacement: passo 2, immagine 1 di 3 HP Officejet Pro 8625 Motherboard Replacement: passo 2, immagine 2 di 3 HP Officejet Pro 8625 Motherboard Replacement: passo 2, immagine 3 di 3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Motherboard Replacement: passo 3, immagine 1 di 2 HP Officejet Pro 8625 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  5. HP Officejet Pro 8625 Motherboard Replacement: passo 5, immagine 1 di 2 HP Officejet Pro 8625 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  6. HP Officejet Pro 8625 Motherboard Replacement: passo 6, immagine 1 di 3 HP Officejet Pro 8625 Motherboard Replacement: passo 6, immagine 2 di 3 HP Officejet Pro 8625 Motherboard Replacement: passo 6, immagine 3 di 3
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
Conclusione
Cam Engle
Membro da: 10/08/18
555 Reputazione
3 Guide realizzate
Cal Poly, Team S13-G3, White Fall 2018 Membro di Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 521
