Salta al contenuto principale
HP Officejet Pro 8625 Display Replacement
Cosa ti serve
    1. HP Officejet Pro 8625 Display  Replacement, Display Motherboard: passo 1, immagine 1 di 2 HP Officejet Pro 8625 Display  Replacement, Display Motherboard: passo 1, immagine 2 di 2
      • Disconnect the display by holding it in place while pulling down on the plastic hinge.
      • Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP Officejet Pro 8625 Display  Replacement: passo 2, immagine 1 di 3 HP Officejet Pro 8625 Display  Replacement: passo 2, immagine 2 di 3 HP Officejet Pro 8625 Display  Replacement: passo 2, immagine 3 di 3
      • Lift the display as high as it will allow to expose the back of the display.
      • Pinch the sides of the cover and pull away from the printer to reveal the connector.
      • Remove the connector by pulling both away from the display and towards the printer.
      Chiedi a FixBot
      Aggiungi Commento
    3. HP Officejet Pro 8625 Display  Replacement: passo 3, immagine 1 di 3 HP Officejet Pro 8625 Display  Replacement: passo 3, immagine 2 di 3 HP Officejet Pro 8625 Display  Replacement: passo 3, immagine 3 di 3
      • Remove the four 6.2 mm T9 screws from the back of the display.
      • Pull the display assembly up and away from the printer.
      Chiedi a FixBot
      Aggiungi Commento
    4. HP Officejet Pro 8625 Display  Replacement: passo 4, immagine 1 di 2 HP Officejet Pro 8625 Display  Replacement: passo 4, immagine 2 di 2
      • Remove the back cover from the display assembly by pressing down on the point of connection.
      • If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
      Chiedi a FixBot
      Aggiungi Commento
    5. HP Officejet Pro 8625 Display  Replacement: passo 5, immagine 1 di 2 HP Officejet Pro 8625 Display  Replacement: passo 5, immagine 2 di 2
      • Remove the four 4.8 mm T6 screws from the back of the display motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    6. HP Officejet Pro 8625 Display  Replacement: passo 6, immagine 1 di 2 HP Officejet Pro 8625 Display  Replacement: passo 6, immagine 2 di 2
      • Remove the connection on the front of the display motherboard.
      • Remove the display motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    1. HP Officejet Pro 8625 Display  Replacement, Display: passo 7, immagine 1 di 2 HP Officejet Pro 8625 Display  Replacement, Display: passo 7, immagine 2 di 2
      • Remove the four 4.8 mm screws from the back of the display using a T6 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP Officejet Pro 8625 Display  Replacement: passo 8, immagine 1 di 3 HP Officejet Pro 8625 Display  Replacement: passo 8, immagine 2 di 3 HP Officejet Pro 8625 Display  Replacement: passo 8, immagine 3 di 3
      • Lift the display out of the case.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S13-G3, White Fall 2018 Membro di Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 26
Tutti i Tempi: 886
