Salta al contenuto principale
HP Officejet Pro 8620 Power Adapter Replacement
Cosa ti serve
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: passo 1, immagine 1 di 3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: passo 1, immagine 2 di 3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: passo 1, immagine 3 di 3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: passo 2, immagine 1 di 2 HP Officejet Pro 8620 Power Adapter Replacement: passo 2, immagine 2 di 2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: passo 3, immagine 1 di 2 HP Officejet Pro 8620 Power Adapter Replacement: passo 3, immagine 2 di 2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: passo 4, immagine 1 di 3 HP Officejet Pro 8620 Power Adapter Replacement: passo 4, immagine 2 di 3 HP Officejet Pro 8620 Power Adapter Replacement: passo 4, immagine 3 di 3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: passo 5, immagine 1 di 3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: passo 5, immagine 2 di 3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: passo 5, immagine 3 di 3
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: passo 6, immagine 1 di 3 HP Officejet Pro 8620 Power Adapter Replacement: passo 6, immagine 2 di 3 HP Officejet Pro 8620 Power Adapter Replacement: passo 6, immagine 3 di 3
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: passo 7, immagine 1 di 1
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: passo 8, immagine 1 di 1
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
Conclusione
Scott
Membro da: 01/24/18
593 Reputazione
3 Guide realizzate
Cal Poly, Team S19-G2, Livingston Spring 2018 Membro di Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Membro
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,173
