Salta al contenuto principale
HP Officejet Pro 8620 Display Replacement
Cosa ti serve
  1. HP Officejet Pro 8620 Display Replacement, Display: passo 1, immagine 1 di 2 HP Officejet Pro 8620 Display Replacement, Display: passo 1, immagine 2 di 2
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: passo 2, immagine 1 di 3 HP Officejet Pro 8620 Display Replacement: passo 2, immagine 2 di 3 HP Officejet Pro 8620 Display Replacement: passo 2, immagine 3 di 3
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: passo 3, immagine 1 di 3 HP Officejet Pro 8620 Display Replacement: passo 3, immagine 2 di 3 HP Officejet Pro 8620 Display Replacement: passo 3, immagine 3 di 3
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: passo 4, immagine 1 di 2 HP Officejet Pro 8620 Display Replacement: passo 4, immagine 2 di 2
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
Conclusione
Altre 4 persone hanno completato questa guida.
Dallas Rocha
Membro da: 01/24/18
243 Reputazione
1 Guida realizzata
Cal Poly, Team S19-G2, Livingston Winter 2018 Membro di Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,866
