Salta al contenuto principale
HP Officejet Pro 8620 CMOS Battery Replacement
Cosa ti serve
  1. HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: passo 1, immagine 1 di 3 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: passo 1, immagine 2 di 3 HP Officejet Pro 8620 CMOS Battery Replacement, Left Panel: passo 1, immagine 3 di 3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 CMOS Battery Replacement: passo 2, immagine 1 di 2 HP Officejet Pro 8620 CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 CMOS Battery Replacement: passo 3, immagine 1 di 2 HP Officejet Pro 8620 CMOS Battery Replacement: passo 3, immagine 2 di 2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 CMOS Battery Replacement: passo 4, immagine 1 di 3 HP Officejet Pro 8620 CMOS Battery Replacement: passo 4, immagine 2 di 3 HP Officejet Pro 8620 CMOS Battery Replacement: passo 4, immagine 3 di 3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 CMOS Battery Replacement, CMOS Battery: passo 5, immagine 1 di 1
    • Gently bend the black ribbon cable by using your left hand.
    • Remove the 8mm T9-Torx screw under the black plastic cover by turning counter clockwise.
  6. HP Officejet Pro 8620 CMOS Battery Replacement: passo 6, immagine 1 di 2 HP Officejet Pro 8620 CMOS Battery Replacement: passo 6, immagine 2 di 2
    • Gently move the black plastic cover to the side by using your right hand.
    • Place one finger behind the top of the motherboard where you removed the previous screw.
    • Gently pull the motherboard towards you by about an inch by using your right hand's finger.
  7. HP Officejet Pro 8620 CMOS Battery Replacement: passo 7, immagine 1 di 1
    • Gently remove the CMOS battery by using a finger from your left hand, while holding the motherboard with your right hand.
Conclusione
Altre 5 persone hanno completato questa guida.
Michael
Membro da: 01/24/18
331 Reputazione
1 Guida realizzata
Cal Poly, Team S19-G2, Livingston Winter 2018 Membro di Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Membri
8 Guide realizzate
3 Commenti
I removed the lithium CMOS 3 volt battery, connected 2 wires at +(red) and - (black). Open a hole at plastic cover, and now I’m using 2 AA in serial, in a holder externally. To refill the cartridges , first open the cover till carriage stops in the middle. Second disconnect the 120 V power cable. Third remove the external CMOS 2 AA batteries, from the holder . Forth remove ink cartridges, refill and install them in the carriage. Insert exterior CMOS 2 AA batteries in the holder, Connect the power cable and you are good to go.
Arbaches Glaukus - Replica
I removed all the board fasteners to be sure. That small metal hook down below your right thumb. Be careful there no to damage the board. 10 minutes and done!
servehimdaily - Replica
Apparently the screws are T10 not T9. T9 works but you'll slightly damage the screw.
dbovey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 170
Tutti i Tempi: 11,236
