Introduzione
The CMOS battery is an on board electronics memory storage battery. Removing it will reset all settings to default. If your printer frequently loses data or shuts off randomly, you may need to replace the CMOS battery.
Cosa ti serve
Turn off the printer and remove the power cable.
Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
Gently bend the black ribbon cable by using your left hand.
Remove the 8mm T9-Torx screw under the black plastic cover by turning counter clockwise.
Altre 5 persone hanno completato questa guida.
3 Commenti
I removed the lithium CMOS 3 volt battery, connected 2 wires at +(red) and - (black). Open a hole at plastic cover, and now I’m using 2 AA in serial, in a holder externally. To refill the cartridges , first open the cover till carriage stops in the middle. Second disconnect the 120 V power cable. Third remove the external CMOS 2 AA batteries, from the holder . Forth remove ink cartridges, refill and install them in the carriage. Insert exterior CMOS 2 AA batteries in the holder, Connect the power cable and you are good to go.
I removed all the board fasteners to be sure. That small metal hook down below your right thumb. Be careful there no to damage the board. 10 minutes and done!
