Salta al contenuto principale
HP Officejet Pro 8600 Plus Front Panel Replacement
Cosa ti serve
  1. HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: passo 1, immagine 1 di 2 HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: passo 1, immagine 2 di 2
    • Open the front panel door by pulling forward on the slot located on the front-left side of the printer.
  2. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 2, immagine 1 di 2 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 2, immagine 2 di 2
    • Insert the plastic opening tool into the right socket connecting the front panel door to the hinge guide.
    • Pry the socket open, lifting the door hinge guide out of place.
  3. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 3, immagine 1 di 2 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 3, immagine 2 di 2
    • Pull the door-hinge guide to the right to detach its left socket.
    • Lift the door-hinge guide upward and away from the front panel door.
  4. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 4, immagine 1 di 2 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 4, immagine 2 di 2
    • Grab the front panel door close to its hinge on the right side.
    • Pull the front panel door away from the printer toward you.
    • Extra force may be required to pull the door from its hinge.
  5. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 5, immagine 1 di 3 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 5, immagine 2 di 3 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 5, immagine 3 di 3
    • Grab the front panel door close to its two hinges on the left side.
    • Extra force may be required to pull the door from its hinges.
Conclusione
Altre 2 persone hanno completato questa guida.
Maegan Betz
Membro da: 04/18/18
301 Reputazione
1 Guida realizzata
Cal Poly, Team S16-G4, Livingston Spring 2018 Membro di Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 3,733
