Salta al contenuto principale
HP Officejet Pro 6835 Speaker Replacement
Cosa ti serve
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: passo 1, immagine 1 di 1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: passo 2, immagine 1 di 3 HP Officejet Pro 6835 Speaker Replacement: passo 2, immagine 2 di 3 HP Officejet Pro 6835 Speaker Replacement: passo 2, immagine 3 di 3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: passo 3, immagine 1 di 1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: passo 4, immagine 1 di 2 HP Officejet Pro 6835 Speaker Replacement: passo 4, immagine 2 di 2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: passo 5, immagine 1 di 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: passo 5, immagine 2 di 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: passo 5, immagine 3 di 3
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: passo 6, immagine 1 di 1
    • Carefully slide the speaker out of the printer.
Conclusione
David J
Membro da: 01/24/18
169 Reputazione
2 Guide realizzate
Cal Poly, Team S2-G4, Livingston Winter 2018 Membro di Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 289
