Introduzione
To replace the printhead, you need a thin pair of tweezers to get into some small crevasses and a screwdriver to remove screws. Make sure to extract all the ink cartridges from the carriage before starting the disassembly. Check out the troubleshooting page before replacing the printhead to make sure a replacement is absolutely necessary. Be prepared to get ink on your hands, as some components may have ink on them.
Cosa ti serve
Open the main lid as far as it will go.
Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
Open the lid further.
Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
If you have iFixit repair kit, for the two deep screws above the screen assembly you can reach them with:
- the T9 torx bit
- on the 4.0 hexagonal bit
- on the screwdriver
Altre 18 persone hanno completato questa guida.
5 Commenti
The printhead replacement went smooth however, the printer will not now print and the print carriage slams into home position like it is trying to break through the side of the printer. What could be the problem?
The location tape is upside down
Thank you very much for this guide.
I bought a replacement print head from Amazon.
There were some remanufactured on eBay, but the Amazon had some reviews (I know, I know, they’re probably fake).
As a suggestion, on the printhead cables, make sure you pull out the RIBBON and don’t pull the connector. It’s soldered to the board.
It’s easier to just remove the plastic ribbon that guides the print head. Push on the metal frame to ease it out, and then the printhead can be pulled out.
In that way, access to the ribbon connectors is much easier.
My printer had not been working for over 4 years. So, it was not wanting to pull paper. Gave it a thorough cleaning and voilà.
It took a few tries. Got my ink from Amazon, from a company called DoubleD. It works just fine.
Printhead: https://www.amazon.com/dp/B08BF8YGG6?psc...
Ink: https://www.amazon.com/dp/B086MSDWFH?psc...
Thanks again for the guide. Life saver, and the printer was rescued from going to the recycler.
which of the 4 ribbons is the location tape
Better use the pliers (Spitzzange like this). One tip into the hole the other onto the plastic hook, then turn the pliers anticlockwise - and open it is, without any damage :-)
The trick is shown here: https://youtu.be/-PwJhT1_uAw?t=180
Michael Gasperl - Replica
