Salta al contenuto principale
HP Officejet 4630 Scanner Head Replacement
Cosa ti serve
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: passo 1, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: passo 1, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: passo 1, immagine 3 di 3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: passo 2, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 2, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 2, immagine 3 di 3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: passo 3, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 3, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 3, immagine 3 di 3
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: passo 4, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 4, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 4, immagine 3 di 3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: passo 5, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: passo 5, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: passo 5, immagine 3 di 3
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: passo 6, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 6, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 6, immagine 3 di 3
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: passo 7, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 7, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 7, immagine 3 di 3
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: passo 8, immagine 1 di 2 HP Officejet 4630 Scanner Head Replacement: passo 8, immagine 2 di 2
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: passo 9, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 9, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 9, immagine 3 di 3
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: passo 10, immagine 1 di 1
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: passo 11, immagine 1 di 1
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: passo 12, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 12, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 12, immagine 3 di 3
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: passo 13, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 13, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 13, immagine 3 di 3
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: passo 14, immagine 1 di 3 HP Officejet 4630 Scanner Head Replacement: passo 14, immagine 2 di 3 HP Officejet 4630 Scanner Head Replacement: passo 14, immagine 3 di 3
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
Conclusione
Maya Willis
Membro da: 01/24/18
415 Reputazione
3 Guide realizzate
Cal Poly, Team S18-G3, Livingston Winter 2018 Membro di Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,446
