Salta al contenuto principale
HP Officejet 4630 Fax Feeder Replacement
Cosa ti serve
  1. HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: passo 1, immagine 1 di 2 HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: passo 1, immagine 2 di 2
    • Lift the fax feeder cover until it stands on its own.
  2. HP Officejet 4630 Fax Feeder Replacement: passo 2, immagine 1 di 3 HP Officejet 4630 Fax Feeder Replacement: passo 2, immagine 2 di 3 HP Officejet 4630 Fax Feeder Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to unclasp the hinge that holds the feeder cover.
  3. HP Officejet 4630 Fax Feeder Replacement: passo 3, immagine 1 di 2 HP Officejet 4630 Fax Feeder Replacement: passo 3, immagine 2 di 2
    • Lift the green tab to remove the fax feeder from the printer.
  4. HP Officejet 4630 Fax Feeder Replacement: passo 4, immagine 1 di 3 HP Officejet 4630 Fax Feeder Replacement: passo 4, immagine 2 di 3 HP Officejet 4630 Fax Feeder Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to pry the pivot point apart while lifting the feeder up.
    • There is still a cable holding the part to the rest of the printer.
  5. HP Officejet 4630 Fax Feeder Replacement: passo 5, immagine 1 di 2 HP Officejet 4630 Fax Feeder Replacement: passo 5, immagine 2 di 2
    • Use a screwdriver to remove the single 9mm T10 screw.
    • Remove the wire cover and pull the wire away from the printer. The fax feeder head is now free to be separated from the printer.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S18-G3, Livingston Winter 2018 Membro di Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Membri
18 Guide realizzate
Un commento
I am so glad i found this site…I was able to unjam a lease that had gotten stuck…..thank you thank you7… times over…Lee
Lee Shankle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,081
