Salta al contenuto principale
HP OfficeJet 4650 Paper Tray Replacement
Cosa ti serve
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: passo 1, immagine 1 di 2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: passo 1, immagine 2 di 2
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: passo 2, immagine 1 di 2 HP OfficeJet 4650 Paper Tray Replacement: passo 2, immagine 2 di 2
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: passo 3, immagine 1 di 3 HP OfficeJet 4650 Paper Tray Replacement: passo 3, immagine 2 di 3 HP OfficeJet 4650 Paper Tray Replacement: passo 3, immagine 3 di 3
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: passo 4, immagine 1 di 2 HP OfficeJet 4650 Paper Tray Replacement: passo 4, immagine 2 di 2
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: passo 5, immagine 1 di 1
    • Remove the paper tray by pulling the tray away from the printer.
Conclusione
Cal Poly, Team S19-G6, Livingston Winter 2018 Membro di Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Membri
10 Guide realizzate
3 Commenti
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - Replica
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - Replica
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 4,583
