Salta al contenuto principale
HP Notebook 15-ba018ds Fan Replacement
Cosa ti serve
  1. HP Notebook 15-ba018ds Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Fan Replacement: passo 2, immagine 1 di 3 HP Notebook 15-ba018ds Fan Replacement: passo 2, immagine 2 di 3 HP Notebook 15-ba018ds Fan Replacement: passo 2, immagine 3 di 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Fan Replacement, Fan: passo 3, immagine 1 di 2 HP Notebook 15-ba018ds Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Fan Replacement: passo 4, immagine 1 di 1
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Fan Replacement: passo 5, immagine 1 di 2 HP Notebook 15-ba018ds Fan Replacement: passo 5, immagine 2 di 2
    • Remove the three Phillips head screws attached to the fan.
  6. HP Notebook 15-ba018ds Fan Replacement: passo 6, immagine 1 di 2 HP Notebook 15-ba018ds Fan Replacement: passo 6, immagine 2 di 2
    • Remove old fan and replace with a new fan.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,319
