Cosa ti serve
Before disassembling the computer, follow these steps:
Shut down the computer
Disconnect all external devices connected to the computer
Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
To remove the battery:
Position the computer upside down on a flat surface
Slide the battery lock latch (1)
Slide the battery release latch (2)
Remove the battery (3) from the computer
To remove the optical drive:
Remove the Philips PM2.5x6.0 screw (1)
Remove the optical drive (2) by sliding it out of the optical drive bay
To remove the bottom cover:
Position the computer upside down the the front toward you
Remove the two rubber feet from the rear of the bottom of the computer (1)
Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
Remove the solid-state drive
Remove the Philips PM2x2 screw (1) that secures the drive to the system board
Remove the drive (2) by pulling it away from the connector
