Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. Turn off and unplug your laptop. Also, make sure to disconnect all the external devices. After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. Now you're able to remove the battery and the service cover. Slide the battery upward to remove it.
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. Slide the service cover downward. After that, lift the back cover to remove it. After that, lift the back cover to remove it.
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. Unlock the indicated screw in order to remove the optical drive. Slide the optical drive to completely remove it from the laptop. Slide the optical drive to completely remove it from the laptop.
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 118
