Salta al contenuto principale
HP Mobile Thin Client mt41 Fan Replacement
Cosa ti serve
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: passo 1, immagine 1 di 2 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: passo 2, immagine 1 di 2 HP Mobile Thin Client mt41 Fan Replacement: passo 2, immagine 2 di 2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: passo 3, immagine 1 di 1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: passo 4, immagine 1 di 1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: passo 5, immagine 1 di 2 HP Mobile Thin Client mt41 Fan Replacement, Fan: passo 5, immagine 2 di 2
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: passo 6, immagine 1 di 1
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: passo 7, immagine 1 di 1
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 367
