Salta al contenuto principale
HP Mini 210-2070NR RTC Battery Replacement
Cosa ti serve
  1. HP Mini 210-2070NR RTC Battery Replacement, Battery and Service Access Cover: passo 1, immagine 1 di 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RTC Battery Replacement: passo 2, immagine 1 di 3 HP Mini 210-2070NR RTC Battery Replacement: passo 2, immagine 2 di 3 HP Mini 210-2070NR RTC Battery Replacement: passo 2, immagine 3 di 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RTC Battery Replacement: passo 3, immagine 1 di 3 HP Mini 210-2070NR RTC Battery Replacement: passo 3, immagine 2 di 3 HP Mini 210-2070NR RTC Battery Replacement: passo 3, immagine 3 di 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RTC Battery Replacement: passo 4, immagine 1 di 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: passo 5, immagine 1 di 3 HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: passo 5, immagine 2 di 3 HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: passo 5, immagine 3 di 3
    • The RTC battery is a thin disk near the bottom left corner.
    • The black and red cable is the RTC battery cable.
    • Pull the RTC battery cable out of its socket.
  6. HP Mini 210-2070NR RTC Battery Replacement: passo 6, immagine 1 di 2 HP Mini 210-2070NR RTC Battery Replacement: passo 6, immagine 2 di 2
    • Gently pry the RTC battery upward with the plastic opening tool.
    • Remove RTC battery.
    • The RTC battery is attached with double sided tape.
Conclusione
Altre 2 persone hanno completato questa guida.
Alek Linquist
Membro da: 10/05/12
123 Reputazione
2 Guide realizzate
Cal Poly, Team 3-23, Amido Fall 2012 Membro di Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,262
