Introduzione
Use this guide to replace your RAM Card. Replacing your RAM card for one of higher capacity will allow your system to perform better.
Strumenti
Nessun attrezzo specificato.
Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
Altre 2 persone hanno completato questa guida.
