Salta al contenuto principale
HP Mini 210-1199DX RAM Replacement
Cosa ti serve
  1. HP Mini 210-1199DX RAM Replacement, Battery: passo 1, immagine 1 di 2 HP Mini 210-1199DX RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX RAM Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX RAM Replacement, Bottom Cover: passo 3, immagine 1 di 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX RAM Replacement: passo 4, immagine 1 di 3 HP Mini 210-1199DX RAM Replacement: passo 4, immagine 2 di 3 HP Mini 210-1199DX RAM Replacement: passo 4, immagine 3 di 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX RAM Replacement: passo 5, immagine 1 di 1
    • Pull the case off of the device
  6. HP Mini 210-1199DX RAM Replacement, RAM: passo 6, immagine 1 di 1
    • Locate RAM systems.
  7. HP Mini 210-1199DX RAM Replacement: passo 7, immagine 1 di 1
    • Use spudger to carefully pull the holding devices back.
    • RAM should pop out once this is completed.
  8. HP Mini 210-1199DX RAM Replacement: passo 8, immagine 1 di 1
    • Carefully pull the RAM card out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 467
