Introduzione
Overtime the CMOS Battery may drain and need replacement. This can cause a reset in the System Clock and other features of the Mini 210-1199x. In order to fix this, a battery replacement is needed.
Replace the CMOS Battery with a 3-volt 2032-size coin battery.
Cosa ti serve
Unplug the netbook.
Secure the netbook in a upright position.
Slide the plastic battery latch that secures it into the netbook.
Keep thumb secure on the right tab as you begin to remove the battery.
Press down on the two orange buttons to release.
If the case does not pop off, begin to use Spudger to pry the case off the back.
