Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Replacing the WWAN (Wireless Wide Area Network) card is easy and straightforward.
WWAN connectivity allows a user with a netbook and a WWAN card to surf the web, check email, or connect to a virtual private network (VPN) from anywhere within the regional boundaries of cellular service.
The WWAN card in the HP Mini 210 uses a Mini PCIe interface, which is the standard on recent laptops. Please ensure you install an official HP verified WWAN card to prevent running into errors.
  1. Turn off and unplug the netbook before replacing the battery.
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Slide the battery out from the netbook.
    • Slide the battery out from the netbook.
  3. Turn the netbook to view its edge.
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    • Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. Pull the back case off from the front edge.
    • Pull the back case off from the front edge.
  6. Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool. Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
    • Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
  7. Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board. Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
    • Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  8. Remove the WWAN card by pulling the WWAN card out at an angle.
    • Remove the WWAN card by pulling the WWAN card out at an angle.
Conclusione
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
Heather Freed
Membro da: 06/10/2012
648 Reputazione
8 Guide realizzate
Cal Poly, Team 9-17, Amido Fall 2012 Membro di Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Membri
8 Guide realizzate
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 5,185
