Cosa ti serve
Power off the laptop before trying to remove the battery.
Turn the laptop upside down, and locate the sliding tabs on the battery.
Slide both tabs in an inward direction, then slide the battery away from the laptop.
Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
Find the two silver screws that hold the memory card cover.
Take a PH1 screwdriver and unscrew the two screws.
Remove the metal cover
Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
Flip the laptop over and remove the six black screws.
Using a pry stick, removing the two cables from the back of the card.
