Salta al contenuto principale
HP Mini 110-3131dx Wireless Card Replacement
Cosa ti serve
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Wireless Card Replacement, Keyboard: passo 2, immagine 1 di 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  2. HP Mini 110-3131dx Wireless Card Replacement: passo 3, immagine 1 di 3 HP Mini 110-3131dx Wireless Card Replacement: passo 3, immagine 2 di 3 HP Mini 110-3131dx Wireless Card Replacement: passo 3, immagine 3 di 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  3. HP Mini 110-3131dx Wireless Card Replacement: passo 4, immagine 1 di 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
  4. HP Mini 110-3131dx Wireless Card Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  5. HP Mini 110-3131dx Wireless Card Replacement: passo 6, immagine 1 di 2 HP Mini 110-3131dx Wireless Card Replacement: passo 6, immagine 2 di 2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
  6. HP Mini 110-3131dx Wireless Card Replacement, Memory Card: passo 7, immagine 1 di 3 HP Mini 110-3131dx Wireless Card Replacement, Memory Card: passo 7, immagine 2 di 3 HP Mini 110-3131dx Wireless Card Replacement, Memory Card: passo 7, immagine 3 di 3
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  7. HP Mini 110-3131dx Wireless Card Replacement: passo 8, immagine 1 di 2 HP Mini 110-3131dx Wireless Card Replacement: passo 8, immagine 2 di 2
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
  8. HP Mini 110-3131dx Wireless Card Replacement, Keyboard Bezel: passo 9, immagine 1 di 2 HP Mini 110-3131dx Wireless Card Replacement, Keyboard Bezel: passo 9, immagine 2 di 2
    • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
    • Be sure to keep track of which screws go where as they are not all the same size.
    • Flip the laptop over and remove the six black screws.
  9. HP Mini 110-3131dx Wireless Card Replacement: passo 10, immagine 1 di 2 HP Mini 110-3131dx Wireless Card Replacement: passo 10, immagine 2 di 2
    • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
    • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
  10. HP Mini 110-3131dx Wireless Card Replacement: passo 11, immagine 1 di 1
    • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
  11. HP Mini 110-3131dx Wireless Card Replacement, Wireless Card: passo 12, immagine 1 di 1
    • Using a pry stick, removing the two cables from the back of the card.
    • Be sure to remember which cable attaches to which connector on the card. The cable with the white band should be attached to the connector labelled "J2."
  12. HP Mini 110-3131dx Wireless Card Replacement: passo 13, immagine 1 di 1
    • Detach the two 3.4mm screws that is holding down the back of the card with a Phillips PH0 screwdriver.
    • The card is spring loaded at the receptacle. If you are holding it down, the card will jump up once both screws are dissemble.
    • Allow the card to raise up, and then slightly push it out of the black receptacle.
    • As you are putting the card back in, make sure it is fully placed in the receptacle before pushing it back down to place in the screws.
Conclusione
aarondcollege
Membro da: 10/06/16
1.297 Reputazione
10 Guide realizzate
USF Tampa, Team 2-4, Cagle Fall 2016 Membro di USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 356
