Salta al contenuto principale
HP Mini 110-3131dx Screen Replacement
Cosa ti serve
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Screen Replacement, Screen: passo 2, immagine 1 di 3 HP Mini 110-3131dx Screen Replacement, Screen: passo 2, immagine 2 di 3 HP Mini 110-3131dx Screen Replacement, Screen: passo 2, immagine 3 di 3
    • Slightly tilt the screen downward.
    • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
    • Use the plastic opening tool to force the screen bezel from the screen.
    • Locate the eight silver 2.9mm screws attaching the screen to the lid.
    • Using a PH1 philips head screwdriver detach the screws.
Conclusione
aarondcollege
Membro da: 10/06/16
1.297 Reputazione
10 Guide realizzate
USF Tampa, Team 2-4, Cagle Fall 2016 Membro di USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 480
