Salta al contenuto principale
HP Mini 110-3131dx Memory Card Replacement
Cosa ti serve
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Memory Card Replacement, Back Cover: passo 2, immagine 1 di 2 HP Mini 110-3131dx Memory Card Replacement, Back Cover: passo 2, immagine 2 di 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Memory Card Replacement, Memory Card: passo 3, immagine 1 di 3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: passo 3, immagine 2 di 3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: passo 3, immagine 3 di 3
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  3. HP Mini 110-3131dx Memory Card Replacement: passo 4, immagine 1 di 2 HP Mini 110-3131dx Memory Card Replacement: passo 4, immagine 2 di 2
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
Conclusione
To install the new memory card, follow these instructions in reverse order.
aarondcollege
Membro da: 10/06/16
1.297 Reputazione
10 Guide realizzate
USF Tampa, Team 2-4, Cagle Fall 2016 Membro di USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Membri
10 Guide realizzate
Un commento
what ram she using hp mini
ASKAR MALAYA - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 655
