Salta al contenuto principale
HP Mini 110-3131dx Back Cover Replacement
Cosa ti serve
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Back Cover Replacement, Back Cover: passo 2, immagine 1 di 2 HP Mini 110-3131dx Back Cover Replacement, Back Cover: passo 2, immagine 2 di 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
Conclusione
aarondcollege
Membro da: 10/06/16
1.297 Reputazione
10 Guide realizzate
USF Tampa, Team 2-4, Cagle Fall 2016 Membro di USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,093
