Salta al contenuto principale
HP Mini 110-1046NR Memory Card Replacement
Cosa ti serve
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: passo 1, immagine 1 di 3 HP Mini 110-1046NR Memory Card Replacement, Battery: passo 1, immagine 2 di 3 HP Mini 110-1046NR Memory Card Replacement, Battery: passo 1, immagine 3 di 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: passo 2, immagine 1 di 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: passo 2, immagine 2 di 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: passo 2, immagine 3 di 3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: passo 3, immagine 1 di 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: passo 3, immagine 2 di 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: passo 3, immagine 3 di 3
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
Conclusione
Altre 2 persone hanno completato questa guida.
Jared Cooper
Membro da: 10/18/13
649 Reputazione
5 Guide realizzate
Clemson, Team 14-1, Benson Fall 2013 Membro di Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,321
