Salta al contenuto principale
HP Mini 1000 RAM Replacement
Cosa ti serve
  1. HP Mini 1000 RAM Replacement, Battery: passo 1, immagine 1 di 2 HP Mini 1000 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 RAM Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 RAM Replacement, RAM: passo 3, immagine 1 di 2 HP Mini 1000 RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
    • Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
    • At this point, the edge of the RAM compartment cover nearest the battery compartment should pop up from the lower case.
  4. HP Mini 1000 RAM Replacement: passo 4, immagine 1 di 1
    • Remove the RAM compartment cover from the lower case.
  5. HP Mini 1000 RAM Replacement: passo 5, immagine 1 di 2 HP Mini 1000 RAM Replacement: passo 5, immagine 2 di 2
    • Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should pop up slightly from its socket.
    • Pull the RAM chip out of its socket and remove it from the Mini 1000.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,678
