Salta al contenuto principale
HP Mini 1000 Hard Drive Replacement
Cosa ti serve
  1. HP Mini 1000 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Mini 1000 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    Need a battery and a keyboard.
    valfin.teach - Replica
  3. HP Mini 1000 Hard Drive Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. HP Mini 1000 Hard Drive Replacement: passo 4, immagine 1 di 3 HP Mini 1000 Hard Drive Replacement: passo 4, immagine 2 di 3 HP Mini 1000 Hard Drive Replacement: passo 4, immagine 3 di 3
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. HP Mini 1000 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. HP Mini 1000 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
  7. HP Mini 1000 Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 HP Mini 1000 Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
  8. HP Mini 1000 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
  9. HP Mini 1000 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
  10. HP Mini 1000 Hard Drive Replacement: passo 10, immagine 1 di 2 HP Mini 1000 Hard Drive Replacement: passo 10, immagine 2 di 2
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
  11. HP Mini 1000 Hard Drive Replacement, Hard Drive: passo 11, immagine 1 di 2 HP Mini 1000 Hard Drive Replacement, Hard Drive: passo 11, immagine 2 di 2
    • Carefully peel up the two foam bumpers from the ends stuck to the bottom of the hard drive.
    • It is not necessary to peel these bumpers off the hard drive enclosure.
  12. HP Mini 1000 Hard Drive Replacement: passo 12, immagine 1 di 2 HP Mini 1000 Hard Drive Replacement: passo 12, immagine 2 di 2
    • Lift up the center retaining tab on the hard drive enclosure and simultaneously push the hard drive out through the open end of the enclosure.
  13. HP Mini 1000 Hard Drive Replacement: passo 13, immagine 1 di 2 HP Mini 1000 Hard Drive Replacement: passo 13, immagine 2 di 2
    • Pull the hard drive cable out of its socket.
    • Hard drive remains.
Conclusione
Altre 20 persone hanno completato questa guida.
2 Commenti
Great guild, straight forward and easy to follow. Take care disconnecting the hard drive. The clip slides slightly up and then turns up.
Mark - Replica
What’s this hard name? What’s type?
M.h A.f - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 67
Tutti i Tempi: 43,591
