Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The video card is instrumental in the visualization of data by the HP Media Center 876x system. If the images on screen are distorted, of bad quality, or will not appear at all, the video card may require replacement.
Parti
Nessuna parte specificata.
  1. Remove the two (9 mm) hand screws on the back panel. Remove the two (9 mm) hand screws on the back panel.
    • Remove the two (9 mm) hand screws on the back panel.
  2. Place the tower on its side. Slide the side panel horizontally to detach, and pull upward to remove. Slide the side panel horizontally to detach, and pull upward to remove.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Identify the video card (the green card nearest to the fan casing in the bottom left hand corner of the tower).
    • Identify the video card (the green card nearest to the fan casing in the bottom left hand corner of the tower).
  5. Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the video card to its mount.
    • Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the video card to its mount.
  6. Pull the video card vertically out of its port. Pull the video card vertically out of its port.
    • Pull the video card vertically out of its port.
Conclusione
Clemson, Team 6-1, Benson Spring 2014 Membro di Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 243
