Introduzione
The side panel is the main entry port into the inner cavity of the HP Media Center 876x. In order to perform any repairs or replacements, the side panel must be removed.
  1. Remove the two (9 mm) hand screws on the back panel. Remove the two (9 mm) hand screws on the back panel.
    • Remove the two (9 mm) hand screws on the back panel.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
  3. Place the tower on its side. Slide the side panel horizontally to detach, and pull upward to remove. Slide the side panel horizontally to detach, and pull upward to remove.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
Conclusione
Clemson, Team 6-1, Benson Spring 2014 Membro di Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Membri
15 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 107
