Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The internal cooling fan is responsible for maintaining optimal operational conditions for the HP Media Center 876x processor. If your computer will not turn on, or will turn off randomly, then the internal fan may require replacement.
Parti
Nessuna parte specificata.
  1. Remove the two (9 mm) hand screws on the back panel. Remove the two (9 mm) hand screws on the back panel.
    • Remove the two (9 mm) hand screws on the back panel.
  2. Place the tower on its side. Slide the side panel horizontally to detach, and pull upward to remove. Slide the side panel horizontally to detach, and pull upward to remove.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Apply great pressure with fingers on the tabs of the fan casing. While applying pressure, pull the casing upwards to remove.
    • Apply great pressure with fingers on the tabs of the fan casing.
    • While applying pressure, pull the casing upwards to remove.
  5. Simultaneously pull the four corner tabs outward. Grab the center of the fan and slide it, smoothly, outward.
    • Simultaneously pull the four corner tabs outward.
    • Grab the center of the fan and slide it, smoothly, outward.
  6. Remove the fan completely from its casing. Take care not to damage any plastic parts or wires.
    • Remove the fan completely from its casing.
    • Take care not to damage any plastic parts or wires.
Conclusione
Clemson, Team 6-1, Benson Spring 2014 Membro di Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 285
