Introduzione
The CMOS battery is the source of the initial power used in turning the computer on. If your HP Media Center 876x will not turn on, the CMOS battery may need replacement.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
  1. Remove the two (9 mm) hand screws on the back panel. Remove the two (9 mm) hand screws on the back panel.
    • Remove the two (9 mm) hand screws on the back panel.
  2. Place the tower on its side. Slide the side panel horizontally to detach, and pull upward to remove. Slide the side panel horizontally to detach, and pull upward to remove.
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Identify the CMOS battery.
    • Identify the CMOS battery.
  5. Pull battery, in a rolling motion, out of its slot. Pull battery, in a rolling motion, out of its slot. Pull battery, in a rolling motion, out of its slot.
    • Pull battery, in a rolling motion, out of its slot.
Conclusione
Clemson, Team 6-1, Benson Spring 2014 Membro di Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Membri
15 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 499
