Salta al contenuto principale
HP Laserjet Pro 200 Color MFP Wifi Card Replacement
Cosa ti serve
  1. HP Laserjet Pro 200 Color MFP  Wifi Card Replacement, Wifi Card: passo 1, immagine 1 di 2 HP Laserjet Pro 200 Color MFP  Wifi Card Replacement, Wifi Card: passo 1, immagine 2 di 2
    • Turn the printer so that the front is facing to your left.
    • Flip the printer so that it is laying with its left side facing down and the bottom facing you.
  2. HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 2, immagine 1 di 1
    • Use a #2 Phillips head screwdriver to unscrew the 8mm screw on the top edge of the printer.
  3. HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 3, immagine 1 di 3 HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 3, immagine 2 di 3 HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 3, immagine 3 di 3
    • There are three tabs along the back right corner of the printer underneath the panel (location is displayed in the second picture).
    • Use a flathead screwdriver to depress the three tabs along the back the tabs while lightly pulling the panel towards you.
    • Begin with the upmost tab and move your way down, individually depressing the tabs.
    • Pull the panel towards you and remove it from the printer.
  4. HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 4, immagine 1 di 1
    • Turn the printer so that the open side is facing you.
  5. HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 5, immagine 1 di 2 HP Laserjet Pro 200 Color MFP  Wifi Card Replacement: passo 5, immagine 2 di 2
    • Remove the 6mm Phillips head screw using a Phillips #2 screwdriver to disconnect the WiFi card from the motherboard.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S9-G14, Maness Spring 2019 Membro di Cal Poly, Team S9-G14, Maness Spring 2019
CPSU-MANESS-S19S9G14
4 Membri
11 Guide realizzate
Un commento
It’s worth to notice, that putting it all back together is not that simple as it sounds, at least in my case it wasn’t. The front part of the panel has to go in first. Pay extra attention if the vertical edge on the front panel is aligned with the rest of the printer. If it isn’t, it won’t snap in afterwards, so you have to ensure that first. At least I had to.
The negative aspect of that approach is that it will take extra force to put the back part (with the tabs you were depressing) in. I had to help myself with WD-40 as the plastic wouldn’t bend far enough to loosely go into the place.
Also, the turn-on button can not be pressed in when putting it all together as it will block itself on the power switch internal case. Forcing it in will only cause the button to break.
Rsa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 43
Tutti i Tempi: 3,374
