Cosa ti serve
Pull on the two tabs on the back of the printer to release the left side cover.
Remove the cover by rotating it towards the front of the printer.
With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
Lift the cover off of the printer.
Remove 2 screws on the back of the printer, one on the left, and one on the front.
Disconnect one cable from the main board of the printer.
Disconnect the duplexer solenoid cable from the duplexer PCB.
Remove one screw on the duplexer PCB and remove the PCB from the printer.
Remove 3 screws holding the duplexer gears to the printer and remove the gears.
Disconnect the fan cable from the main board of the printer.
Remove the retaining clip holding the fan in.
Remove the 2 screws holding the fan in.
Remove 4 screws on the right side of the printer and remove the main gear assembly.
Remove one screw and remove the tray 2 pickup solenoid.
Disconnect 2 cables from the main board of the printer.
Remove the gear from the fuser shaft by pressing on the tab with a spudger or similar tool.
Remove the remaining cables from the cable guide.
