Salta al contenuto principale
HP HDX 16-1160US Wifi Card Replacement
Cosa ti serve
  1. HP HDX 16-1160US Wifi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Wifi Card Replacement: passo 2, immagine 1 di 3 HP HDX 16-1160US Wifi Card Replacement: passo 2, immagine 2 di 3 HP HDX 16-1160US Wifi Card Replacement: passo 2, immagine 3 di 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Wifi Card Replacement: passo 3, immagine 1 di 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: passo 4, immagine 1 di 2 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: passo 4, immagine 2 di 2
    • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
    • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
    • Lift off the Wi-Fi card panel off using the opposite hand.
  5. HP HDX 16-1160US Wifi Card Replacement: passo 5, immagine 1 di 2 HP HDX 16-1160US Wifi Card Replacement: passo 5, immagine 2 di 2
    • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
  6. HP HDX 16-1160US Wifi Card Replacement: passo 6, immagine 1 di 1
    • Remove the two 4mm screws with the Phillips #1 screw driver.
  7. HP HDX 16-1160US Wifi Card Replacement: passo 7, immagine 1 di 1
    • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
    • Using the opposite hand, pull the Wi-Fi card to the left.
    • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
Conclusione
Altre 2 persone hanno completato questa guida.
Marshall Reid
Membro da: 04/14/14
527 Reputazione
3 Guide realizzate
Cal Poly, Team 12-38, Maness Spring 2014 Membro di Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,154
